1 - 12 of 12 Posts
I've decided to pick up a 6.0 iron block motor to go in the 98' roller I just bought. Car is a 6 speed. It will primarily be a street car with an occasional trip to the track. Drivability isn't a big concern either. And I'm also considering pulling the heads odd and milling them down. I will also be spraying this car. Any thoughts or suggestions?
Those 2 sentences contradict each other. You can go mild to wild based on this info. How much spray? Got a good tuner? What intake setup? Free flowing exhaust? The devil is in the details.
I meant that I don't mind driving a big cam on the street. It will have a good flowing exhaust, and ls6 intake. Putting a fjo progressive and as much spray as I can. I don't really wanna rev it to the moon either
i had a texas speed torquer v3 in my stuck ls1 w 5.3 heads and ls6 intake and made 405 to the wheels. it sounds good and no drivability issues
LQ4 or LQ9 shortblock? What year is it? The earlier truck engines had crankshafts that won't accept a pilot bearing/bushing for the T56.
Mike
236/248 comp xer lobes. 114 +2.
just throwing something out there that might work lol.no cam guru so maybe the experts will chime in to help.
That's the biggest that I would go but it should work well. the 248 lobe is like .615 lift IIRC.
Be sure to check PTV
correct. i can't remember but the 236 is probably around .598"- .601" or so. maybe 4* smaller on both might still work well but a 244* is still .612" . i like the xer lobes pretty well. the springs seem to last forever and the lift is still big enough to get alot of power, especially out of a head that will be done before .600" lift.
1 - 12 of 12 Posts
