1 - 7 of 7 Posts
yes i know this is not the trans forum, but could not get the post new topic to work.
2600lbs n/a 1400 hp , all out race pg1.80 straight cut.only 8 clutch drum.
what coverters do you all run?
Will the 8 clutches hld up?? or do i need a 10 clutch set-up?
thank you all in advance. first motor over 1,000hp.:D
T/S 368E
8 clutch is fine for 1400 HP. Don't sweat that. You might want to check out a 9" Max duty from Coan. Had good luck mostly with them.
1 - 7 of 7 Posts
