1 - 9 of 9 Posts
when welding up a mild steel roll bar can you just use a mig welder or does it have to be tig welded?
The Warbird
Mig is fine, just make sure you are burning hot enough to penetrate the metal and not just lay a bead on top.
Yep, MIG will do it, but we always prefer to TIG weld for better heat control. MIG sure is quicker and easier, though!
Discussion Starter · #8 ·
Good to know thank you!
Master Fabricator
I would have to disagree on the part that MIG is easier on roll cage tubing. I could never get it down with tubing, so I got a TIG and can run nice welds all day long on tubing.
MIG is faster for sure...
1 - 9 of 9 Posts
