Not trying to step on toes, or sound like I am talking down, but if you do not weld SS, then you should not be fitting it either. 99% of the work is fitting it, if done correctly. If it is fit correctly, then the welding is very quick, easy, and turns out beautifully. The other side is that it needs to be welded in order so the welder can get to everything. If it is not done correctly, then the welding becomes the majority of the work. I understand what it is like to have to work with in budget, but you should save up some more cash, and take it to someone in your area that is competent and have them do the whole job. The job will turn out 100% better, unless you are some one that can fit tubing so there is 0 gap, and have everything deburr'd.
