1 - 9 of 9 Posts
can you weld to a cast aluminum valve cover? thanks john
Senior phuckstick
Clean it well.
Just a heads up- It's been found that using Brake cleaner, then welding aluminum with a tig can create very deadly fumes. There was a thread posting a few months ago that covers this topic too.
Clean it well.
one of the few "50 state" product i prefer, you can keep that old school brakekleen, I got a can of it from florida and only used it once, only can of brakekleen that doesnt seem to go faster than the beer
I'm a novice aluminum welder, so right or wrong, when welding used cast aluminum (valve covers or intakes)I heat it with a torch and "burn" the oil out of it, makes it easier to weld with my 185 tig too
thanks for the info guys john
Yes you can weld on them. Are you adding a fitting or are you fixing a crack? If adding a fitting just weld it up. If you have a crack then you might have a problem as some castings have tension in them and the crack seems to come right back when it cools. it can be a pita.
Discussion Starter · #8 ·
im adding a take off for vacuum gauge and oil fill.
1 - 9 of 9 Posts
