I have seen the HVC Coils jump about a 2 1/2" gap and blue all the way, christ you could almost weld with it.
You may want to call MSD and ask them what the resistance between the primary's should be. I know they did have some trouble with the primary circut on the HVC coil.
Couple of questions, Is the Band around the coil grounded? It should be. How old are the Plug wires? Anything over a year should be replaced. What is the Gap on the plugs? Anytime you shoot Nitrous to an engine, you should tighten up the gap.
Letme know,
I hope this helps
Sparky
Letme know,
I hope this helps
Sparky
