1 - 7 of 7 Posts
Just wondering what people running a DRCE-1 are doing to get their water temperature, I was thinking of drilling/tapping one of the water fittings at the front of the cylinder heads. Any input on the subject would be appreciated.
Thanks, Dave
Thanks, Dave
Some check water in heads and block.You see moroso waterneck fitting in main return line with cap area to fill water.
No water cross over tube on intake or water manifold with 4 lines into 1 that goes to radiator?
Yes, I'm using a 4 into 1 manifold....that is another option that I have.
I used and electric gauge put sensor in back side of head but it's a very tight fit to firewall I had massage it a little. Now with new motor I put it in the -16 y fitting going to upper radiator hose.
1 - 7 of 7 Posts
