1 - 10 of 10 Posts
I'm attempting to mount a nozzle ABOVE the carb on roots blown carb.
Anyone have a picture or description of what works and have seen this before?
Thanks Mike,,,but do I point it straight down? All in one venturi????
Or shooting over the carb?
yes straight down,1" above the carb but the rest is how you think your engine runs if the plugs look the same,rich,lean..
Discussion Starter #9
Single carb standard mount with air filter.
I made a stud mount last night. I'll try and get a picture.
That will be fun to see.How much will you spray,325 ml/min?I am sure it will mix well in the intake because the spray pattern is so fine to begin with but I said 1" above the carb as to not effect intake flow to the carb and not leave a stain or shadow in the venturi.
1 - 10 of 10 Posts
