1 - 13 of 13 Posts
· Registered
You can take a small intercooler core and make one or you can sink something like a B&M cooler into a box. We make them out of intercooler cores and they work great. Simply run water in one direction and tranny fluid through one half of the core, then send it back through the other half (2 pass cooler).
I've seen others that sink a regular cooler into a aluminum box and they work well too. I have not seen one actually in the water tank itself. The primary reason is that it's a constant heat sink when you go to stuff more ice into the box.
We run one on one of our cars and it works awesome to keep the trans temp down while on the brake under boost.
· Registered
cooler
I've got a 3 door S-10 with a single 106.I ran 3/8 aluminum line to
the water tank and coiled 10 ft of it in the tank using bulkheads with
aluminum washers.It works great as long as you have plenty of ice in the tank.
· Registered
the easy thing to do is call auto cycle marine and get a cooler they have one that you can mount out side of your water cell that will run off of your water return from your intercooler and then it will not heat your water cell as much when you put it in the cell you melt your ice faster and you don't want that. the # is 248-280-1171
· Registered
Pande:
My finger's resting on the phone, ready to make a call to the bearing people. Only trouble is I don't know what brand you're looking to get (our conversation yesterday PM).
Do you still need these?
1 - 13 of 13 Posts
