1 - 8 of 8 Posts
Wanting to make 1200 hp on a street/strip car have heard a few different things but wanted to get your guys opinions, so what size, AR housing, and what brand do u guys prefer and what compression would u reccomend for a 410 lsx
Are you wanting 1200 crank or rwhp?? Big difference.
If you want quick spool for street manners go with the GT55-94. You can get it in cast or billet. Also can be had in journal and ball bearing design. Unit will make 1200rwhp no problem.
Can I get this in a kit as far as everything needed possible
Yes, we carry the units, wastegate, blow off valve and flanges needed. If your looking for a complete turbo kit (piping kit), their really isn't one out that supports that size unit off the shelf kit wise.
Discussion Starter #7
Is it possible to work up a quote including piping coldside hot side and headers and everything else and I'll just have it bent and welded
You might want to contact Josh at Kentucky Turbo and Performance. He uses Dr. Turbo as a supplier I believe, I was quoted like $8500 for a full system, Precision Pro Mod 98, A2W, All piping, Headers, and coating.
1 - 8 of 8 Posts
