1 - 3 of 3 Posts
checked the spring pressure with vacuum pump opened at 15 lbs changed springs now it opens at 4 lbs now the mbc should let me set boost around ten correct?
yes u should b ok. they say 10lbs more than the spring but ive seen 15 work
1 - 3 of 3 Posts
