1 - 16 of 16 Posts
AMP Racing member
Discussion Starter #2
Ok, so posting on my phone sucks.
Waste gate placement question.
From what I understand, it’s best to have them as close to the turbine as possible.
So, should I put both of them in the lower left of the pic I posted?
Is it ok to put the pass side gate right at the bend off the header?
thanks!
AMP Racing member
Discussion Starter #8
Thanks all. Perhaps I was overthinking it a bit.
AMP Racing member
Discussion Starter #11
So, this is where they ended up
Thanks for the suggestions.
86122
outside the elbow would work great. for optimal control the flow should aim straight at wastegate rather than the turbine.
The placement looks good. I recommend putting braces on the WG tubes. It's a lot of pipe hanging out there. Seen many gates crack or fall off completely..
1 - 16 of 16 Posts
