1 - 2 of 2 Posts
how do i control my boost pressure with high back pressure by using a ams1000 controller and using the wastegate like a high pressure valve?? i was told you can put high pressure to the wastegate and make the turbo spool without going to a bigger exhaust housing.how do i control the amount of boost??
www.nlrsystems.com
click on parts catalog and then download the manual.
The controller applies air to the top of the gate which closes the valve this increasing exhaust flow to the turbine wheel which nets more compressor speed . This equals boost pressure.
Apply 5 on the gate and see what it makes for boost
apply 10 on the gate and see what it makes for boost
do this until youve made all the boost you want.
The kit comes with a 100 psi sensor. This means you can apply 100 psi to the top of the gate.
Seb
1 - 2 of 2 Posts
