1 - 11 of 11 Posts
gen 6 over 30,bullet cam,5000 stall coan converter, victor jr, prosystem 1150 on alcahol, p/g, 4.56,3000 lb car is running 6.22 want to run 5.90s, dont want to put nitrous on car , to much to mess with have had it before. HELP with any ideas.:rolleyes:
Drop off over 2 tenths, can you remove 200 lbs? I take it your not looking to rebuild.
What all has been done to Intake and heads?
Also, it will take some power to make this jump. N/A is going to take some changes in cases, if your combo is worked out now.
Induction/Combination, are where you need to look.
You didn't mention cam spec's?
Working on Heads, Intake & Cam should get you there.
Gen 6 what? 454 or 502? Guessing 454 so you now have a 489?
Which Dart Pro1 heads?
5.90's in 3000# car will probably take in the 750 hp range.
If it is the Bow Tie block open that sucker up to a 4.600" bore.
Enless the heads have been worked on there are not the best to use to get more power.
1 - 11 of 11 Posts
