Vortech V-1 Si-Trim Supercharger
View larger image
Performance Specs
Max Speed: 55000 RPM Max Boost: 26 PSI Max Flow: 1150 CFM Max Power: 775 HP Peak Efficiency: 78% Performance specs apply to units equipped with heavy duty gearcase.
Dimensions
Discharge OD: 2.75" Inlet OD: 3.5" Discharge ID: 2.38" Inducer Diameter: 3.1"
Part Numbers and Prices listed below.
Ideal for latest generation of improved breathing, high-power street and strip engines. Vastly improved flow and efficiency at high boost levels, providing completely new levels of power gain.
Superchargers exceeding 6 PSI require a Vortech standard bypass valve or a Vortech Maxflow racing bypass valve.
Superchargers exceeding 10 PSI require a Vortech Maxflow Mondo or Maxflow racing bypass valve.
Cog belt drive systems are recommended for all heavy duty superchargers
Warranty Information
No Warranty No warranty on race/heavy-duty superchargers.
PNDescriptionPriceSelect
2A128-190 V-1 Si-Trim, Heavy-Duty, Clockwise, Curved Discharge, Satin
