1 - 13 of 13 Posts
Will you be at MIR Friday for odr . Can't make at down this time.
Banned
Dumb question of the day: what is he hitting on the upper front bar/roof that he is revving the motor? sorry im a street car guy, all that shit he has in there is foreign to me.
Banned
Dumbass off the day = me. i figured he was purging it, but is that like a throttle switch tied in to the nitrous system??
when you purge thru the engine the driver will bring the rpm up with the gas pedal a few thousand rpm and hold it steady then activate the nitrous system manually which raises the rpm because its adding extra fuel and air without opening the throttle blades more. I assume that's what you are referring to
he is adding fuel and nos,called banging the system(s) also checking to hear if it is clean,we use it to also check to see if the is a popping or backfire,could show a potential problem before the run.
1 - 13 of 13 Posts
