1 - 4 of 4 Posts
I am building my 340 up and would like to change intakes. have holley strip dom. on it now and want to go vic. 340 or super vic. which one do you guys recommend and why? combo is 71 scamp 344 cu 11.6 comp.eddy rpm heads full ported. has a 2.02 in. valve thinking about putting in 2.08 valve. soild roller .665 lift 258/262 dur. 108 lc installed at 103. 727 trans 4.30 gear 28 tall tire and will try a 26 tall. have a 3800 stall will be changing that too around 4500 to 5000 stall.
If you stick a tapered spacer under the carb on a Super Victor it will outperform the victor intake with any spacer combo.
Brian
i have a 4 hole hvh 1in spacer. is that what you are recommending?
1 - 4 of 4 Posts
