1 - 10 of 10 Posts
I have a 1050 Dominaotor on my 496. I had the car running in the driveway and I did a few hits after it warmed up since its been raining and cant get to the track. Anyhow after I shut her down I noticed some vapors coming from the front bowls. Is that normal? Never paid attention to that. And by the way I cut a .001 light with a 1.10 60 ft. in my driveway;)
I'd say it's probably normal, especially if the carb was plenty hot. Some fuels will do it worse than others. What fuel are you using? You must have a well prepped driveway!
Using VP110. concrete to asphalt driveway. I don't get crazy with it. Don't want to have the car in my basement.
Q(t)=ṁCpΔT
A match will make that go away.
That's why there is a Coast Guard regulation requiring a flame arrestor. If you had an air cleaner on that, like you should, you wouldn't see it. Might smell it, but you wouldn't have seen it.
A good shop vac will pull those vapors away....;)
What happens next might not be good though....:eek:
1 - 10 of 10 Posts
