1 - 3 of 3 Posts
Hi
i have a 284 292 @ 0.50 camshaft with 114 lobe sep and itcl 110
765 lift int 733 exh lift
what valvespring do you rekomend for this camshaft
seat pressure at 2.0 inch ?
i have now 245 lbs at 2.0 inch seat pressure 1.55 valvespring
is this to low
To try answer that with some accuracy
People would need the lobe family. Rocker ratio weight of valve and Max RPM
To try and help you
Hi
is this to low
Need -
lobe durations @ .020"
peak rpm
valve weights
lifts @ retainer with actual spring on it/lash in it
1 - 3 of 3 Posts
