1 - 4 of 4 Posts
Turbo Terror
If you have a set of wheels that have been drilled out for tubes, then decide to remove the tubes to say run radials...
does anyone have a line or info on metal valve stems that will work in wheels that have been drilled out for tube (size) stems?
If there drilled out to 5/8. I would think most any racing wheel distributer would have them. I know summit lists a few different brands. Mr Gasket, Longacre, and Summit brand to name a few.
Mike
I have a set of 8" wide Welds that I drilled the holes out for M/T tubes, I put the slicks on a set of 10"s and give the rims to my buddy and a regular rubber valve stem popped right back in.
1 - 4 of 4 Posts
