1 - 2 of 2 Posts
bullet ground the cam for me.my engine builder set the heads up for me.the car pops something terribel on spray.i called bullet friday and they said 280-320 spring pressure on the seat.i checked this morning and found 200-225 would this cause popping and back firering. on nos
if you're floating valves due to inadequate spring pressure, then it would cause it to pop. why are your springs so light? were they initially in the 280-320 lbs range?
1 - 2 of 2 Posts
