1 - 12 of 12 Posts
if my cam card says to adjust my valves 26 intake 28 exhaust i assume that's with the engine warm what would be a good setting when its cold it is a solid roller thanks in advance
Stuck in Lidsville
IMO 22 and 24 would be a good start, HOWEVER I would check them hot also...
Cold lash will be different with aluminum heads or iron heads (and block). Big block or small block. IIRC-with a sb/aluminum heads I went about .0016 cold to get .0020 hot.
We set them .004" tight when cold on our aluminum head sbc, cast iron dart little m block w/ AFR 227 heads.
So how much tight for an iron head/iron block solid roller?
1 - 12 of 12 Posts
