1 - 9 of 9 Posts
My Own Worst Enemy
They are very similar to the search function.
The pro's: you will find multiple threads that will answer your question.
The con's: you will actually have to put some effort into finding an answer to your question.
Its my experience you can never go wrong running a pump. The con is the fact of more plumbing, mouting and getting a belt to work, and in general more "stuff" under your hood to work around.
J&E POWER!!
i put one on my bbc twin setup this year, biggest thing i noticed is my brad penn oil doesn't look like frothy vomit anymore in the valve covers and coming out of the pan, so thats a plus :)
TURBOBULLET.COM BITCHES!
What puke tank did you run with it Bill? I just put a star machine mountain motor pump on mine, and they said I'd need a big breather tank.
J&E POWER!!
i have the kit from product engineering, it comes with everything, and the tank is TINY. I'm only pulling about 5" vac right now, never changed anything in the motor from running without the pump. drain about a tablespoon of water every pass from the tank.
http://www.product-engr.com/vacuum_system.htm
Discussion Starter #8
I did use the search function. and thank you for your useless reply.
1 - 9 of 9 Posts
