DOSE ANYONE HAVE ANY SUGGUSTIONS , I MADE 4 PASSES ON A NEW COMBO WITH A MOROSO 4 VANE VACUUM PUMP AND VACUUM LOOKED GOOD ACROSS THE LINE ABOUT 14 ,BUT AFTER THE 4 PAS HEARD A NOISE AND THE VACUUM PULL UP THE CENTER OF MY STEEL OIL PAN AND WAS HITTING THE BALANCE WEIGHT ON THE CRANK SHAFT , THE ONLY THING THAT STOPPED IT WAS THE MAIN CAP , ANYBODY THANKS FOR ANY SUGGESTIONS,DARREN
Do you have a guage inside the car so you know it only has 14 inches of vacuum in the motor? I run a Moroso enhanced pump and a Moroso aluminium pan and it has 14 inches and it's been fine 140 passes now. Only thing I can think of is the thing is seeing too much vacuum inside the motor. Maybe the regulator can't vent enough or something? RM
OOPS, I figured it might not of had one.... Not sure now, Your post makes me think you have run data
" across the board " If it is not drawing too much vacuum, the pan just must be too close to deal with it. I would probably pull the pan and see if a stiffiner is plausable in the area of the rub to just keep the two apart.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Yellow Bullet Forums
