1 - 7 of 7 Posts
Is there a reason why you should connect the suction side
to the valve cover and not the old fuel pump mounting location ?
I have not made the connection yet but was considering the fuel
pump block off plate as it would be simpler to modify than my valve covers.
Is one better than the other and why ?
I pondered that same questions years ago. I recall trying putting the fitting as high as I could on the side of the oil pan. But I cannot recall what resulted from that experiment.
1 - 7 of 7 Posts
