1 - 4 of 4 Posts
I have a question.
Where can I hook the vacuum lines for the regulator, map sensor, and bov??
The carb hat or under the carb in the intake?
BOV goes below the carb, fuel pressure regulator goes above the carb and most map sensors go below the carb! If you are using the map sensor to control timing, it needs to be on a dedicated line below the carb to make sure it reads properly.
Thanks for the quick response! I appreciate it
1 - 4 of 4 Posts
