can you pug a vnet extension cable directly into the v300sd vnet port, or do you have to use the short vnet t cable with terminating cap then the extension cable?
You have to have the T starting out of the box and then go from either side of the T. You also have to end both sides of the V Net side with a cap. You can not have a open end.
