Couldn't find exactly what I wanted but was able to get a 4" to 5" transition. I know I saw those dual size V Band Clamps somewhere...Race Parts Solutions? I may need one too if you locate them Tim.
Thanks Jake. I saw them on their website. Didn't look like they had a 4" to 5". I'll just use a transition.Wolfe used to make them. I think thats where I got my 3 1/2 to 4" on the F-2.
Lemme peak at one of my F-3's tommorrow and see if I can come up with a good idea for ya Tim.Thanks Jake. I saw them on their website. Didn't look like they had a 4" to 5". I'll just use a transition.
Its actually a 5" v-band on the hat and a transition under the dash from 4" to 5" feeding the hat.Just spin one out on your lathe there Jake.....you're the MAN!
BTW, Jake, don't you have a 4"-5" v-band on your hat? Or is it a 5" with a transition?
You'd be good to run 5" to the tube atleast 12-18 before the hat to slow the air speed down.May need that on mine. Or atleast a simple sleeve to reduce the 5" down to 4" would be easy. When all welded up you wouldn't be able to tell the difference.
