1 - 7 of 7 Posts
I use my bottle heater to bring the bottle up to pressure then shut it off in the lanes.Then when I'm ready to make a run after the burnout and purge I turn the bottle heater on.My thinking is to help the bottle maintain pressure as it goes down the track.I'm just wondering if this is ideal or should I just leave the heater off.Any thoughts on this would be appreciated .
TRZ Rocks!
I don't think it going to add heat fast enough to make a difference, so then it becomes an unneeded drain on the electrical system. I vote for leave it off.
agree now if u turned on a gas burner on the bottle
that might help :smt066
I agree with BBC, but that presumes you don't have an alternator, but rather one or two batteries only...too much of a drain on battery charge, for a nominal effect on bottle temp. Throw on a bottle heating pad (non-electrical) or even a bottle blanket around the bottle(s).
Thanks for the info guys,I didn't think about the current draw.I think I'll leave it off.
Yeah leave it off, you are talking about what, 10 seconds of nitrous being used. 10 seconds of heat from a bottle heater isn't going to make any difference in the temperature when the cold nitrous is flowing out of it.
1 - 7 of 7 Posts
