1 - 5 of 5 Posts
In a tube chassis car (w/ full cage certified to 8.50et ) with a thick alum front plate, a .090 steel midplate is it advisable to use a solid trans mount like the Moroso piece, is a polyurethane mount ok, or as TCI stresses in their catalog ... "never use a solid trans mount".
Engine will be a BB Chevy mated to a TH400 trans w/a brake.
NEVER, EVER!! Some may get away with one, just not worth breaking cases to try. Poly or rubber will work for you.
Yeah I always wondered if the companies that make the solid mounts are sponsored by a conglomerate of trans housing manufacturers:rolleyes:
T/S 368E
We've had this exact thread several times, and very recently. Some of us use the solid mount as the engine limiter.
Mine is a tube chassis, but not certed to 8.50 (I'm 6.00) Been using solid mount since '94, and been pretty quick with zero breakage.
It's been some like, some don't. Good luck.
Banned
Ran tube chassis Beretta for 12 years and car was run much before that. Front/rear plates and solid trans mount that was removable. Held in place by two quick pins. Never a broken glide tailshaft housing.
The key thing is that if the chassis is not gusseted properly with diagonals and it twists, this is what mostly will break transmissions housings/cases. If your car has any chassis twist to it, install a polyeurethane mount.
1 - 5 of 5 Posts
