201 - 220 of 262 Posts
Yet the USA has the highest case growth in the world.
Your sources for that to prove you are not wrong this time?
And yes, you are a colossal pussy as evidenced by your little blowout with your last thread when asked a simple question and you chose to open the gates of menstrual gravy rather than give a well thought out response backed by accurate information.
fuck the case number...the death rate is all that matters. every country goes the a max uptake at some point,they all go through it at a different time. when its all said and done,,case rates mean squat...the total deaths is the number people care about. when the swine flue hit the usa, under Obama, no one is even remembering the cases now,,yet they sure do remember 12,000 americans DIED
just like when I said Canadas rate was 650% higher than the usa at one point of a daily total..your picking every single one that shows the usa in a bad light...because you hate Trump.
each and every day you get shot down on your bullshit ,,its really embarrassing , yet you double down like a clown
of the top 16 countries in the world right now being hit the hardest, the USA still has the LOWEST death rate per capita than all..by far. except s korea.
lest hope it does not get worse
Discussion Starter #209
Do you seriously not understand why? Italy had few deaths in the first 7-10 days of the upswing too.
Wondering just what virus the test cures?
Discussion Starter #211
Doesnt cure anything but one good example is patient 31 in South Korea refused to get tested, went to church twice, went to a buffet, ended up infecting 300 directly and the cluster grew to 5000+.
One test wouldve prevented that.
Nope. Pill popping frozetard cannot back up said claims with actual data. Like every other liberal clown they simply repeat the same things over and over until they believe it to be true.
Who do liberal fuckwits look up to in a time of need?
This Guy! Girl! It! Thing!
Discussion Starter #213
33,400 positive from CDC today. I was expecting about 38k. This is good. Hopefully the multiplier keeps getting lower each time.
wrong again,,14 countries have as high or HIGHER case growth rate as the USA.
your using bad info again,,as usual just stop,,until you learn where to find the correct data,,keep your mouth shut
you should also stop using cdc data...they are a complete mess right now, do not provide on time data and most times its not correct.
the cdc and the who...two of the worst places to get any info from...also, tests performed as of today in the usa,,300,000.00 plus
this is why
the virus was in the USA 10 days before Italy....tell me why the USA is doing waaaaaay better? why didn't the USA upswing happen BEFORE Italy?
after all,,Italy has more beds, more docs and more nurses than another country with a topped ranked health care system by the WHO
No, the test wouldn't have stopped a thing.
What would have stopped it was not going to church and staying away from the buffet.
Discussion Starter #218
You should get your keyboard tested for corona its spewing commas more than FOX news lies.
You do unerstand the difference between new cases and case growth right?
