1 - 20 of 262 Posts
What is causing this? Testing lag? Did people properly isolate themselves if they had symptoms but couldnt test? Are people not taking this seriously? Saturdays number is 19,500 which follows the tripling trend.
Why is this pill popper always worried about whats going on in the U.S.?
Ain't shit going on in Kanaduh?
Go fuck yourself, twink.
I've noticed the same thing. Get ready allan .... you're going to be told your charts are wrong.
There are large numbers of infected people NOT listed as such, as they have not been tested. Many have no symptoms at all.
Typical example of how statistics can be used to manufacture any conclusion one wants. Considering we had in the beginning near zero test kits to determine if anyone even had the virus and almost no tests were run. Now the numbers of test kits (to do tests) are absolutely miniscule. They can twist and interpret the numbers so that changes say the world will end tomorrow.
NITROUS OUTLET FTW
What is causing this? Testing lag? Did people properly isolate themselves if they had symptoms but couldnt test? Are people not taking this seriously? Saturdays number is 19,500 which follows the tripling trend. View attachment 68578
The fact that horntard jumped to you side to defend the information show how stupid your post and question are.
Try researching a little.
All I care about is when will you and hornturd step out from behind your screens long enough to get it
the increasing availability of RELIABLE, and ACCURATE testing, will spike the numbers in the USA...….Whereas the rest of the world relied upon inaccurate, and bogus testing based on the W.H.O. testing kits, which had an Abysmal accuracy rate. its called REALITY...…….AMERICAN Ingenuity, and reliability, which the world relies upon as the Gold Standard of anything...…………..except horner , poiuyt, and rfc, the THREE Stooges.
1 - 20 of 262 Posts
