1 - 20 of 24 Posts
I posted some video up back around christmas eve when i first fired up my new 408. Back then Timing was around 11 degrees! Done alot of little things since then and wanted to post up an update: This is 30 degrees of timing! This is a pump Gas car btw 55cc chambers,408 with C302 heads , victor intake that I bought off the bullet and a 1,000 cfm HP holley carb. I know it needs alot more tuning but im just happy its slowy coming alive. Have had alot of help from the guys from www.toonutsracing.com/smf .
http://tinypic.com/player.php?v=b64u41&s=7
Man your neighbors must love you!! I thought that guy with the dog was gonna unleash him on you. I cant imagine pulling that off. Sounds like it will get up and scoot once you get it all sorted out. Good luck.
sounds good, my 408 with c3s dosent like more than 30 degrees. be careful with the timing starting out
C302's or C302B's have a cleveland chamber, not the much more efficient chamber of the Yates C3 heads.
Discussion Starter #14
Doug, thing sounds nasty. Good job, working on my 408 now....Tim
I am thinking of building a clevor for a local NA iron headed class, any tips or tricks for them? I have a set of open chambered 2v heads that have been ported and all, going to build either a 393 or 408. class has a 410 in. rule for small blocks and I have to run a flat tappet cam.
I already have them or I would get the 4v heads. These 2v heads look good, they have been ported and cleaned up by a well known porter. I will use a dome piston to get compression up around 13:1. Looking to turn it around 7000-7500
1 - 20 of 24 Posts
