1 - 3 of 3 Posts
Do these new parts work with Auto VB Trans or are they more suited to Manual VB Trans.
Stuff I wish someone made for the 4L80 are:
SFI flexplates for SBC that don't force me to use only 3 out of the 6 bolt holes on the convertor.
SFI Bellhousing or better yet an SFI Case.
SFI Trans shield like what CSR has for the TH400 and 4L60 instead of a dumb blanket.
The parts will work with both auto or manual.
The adjustable pressure regulator will allow normal EPC function to control accumulator pressure but isolates line pressure to a fixed pressure.
The EPC plug works with a stock boost valve as an inexpensive way too run full line.
A SFI bell is available for the 4L80E but it's expensive.
1 - 3 of 3 Posts
