1 - 6 of 6 Posts
I have a 6 AL digital and a digital 2 step with the dials. I'm having an issue with the 2 step. It is set on 3500 rpm and when the transbrake is set and the throttle is depressed it will stutter lightly and then go through the 2 step all the way to the flash on the converter. We have changed the 2 step and the box and still have the issue. Any ideas?
Only things I could think of is checking to make sure it still has a good ground, making sure it has power to it and that it was wired correctly according to MSD's diagrams. If you've already checked those possibilities, then maybe someone more knowledgeable will have another idea or you can give MSD a ring to see what they have to say. Hope you get it figured out quick!
T/S 368E
Change the dials just to make sure the potentiometer isn't jacked up.
If it's still bad, check all the wiring again.
Good luck.
Noise...
I automatically install a noise filter now and run grounded MSD 8662 Shielded cable. EMI can be a bitch. MSD will make custom lengths.
1 - 6 of 6 Posts
