1 - 8 of 8 Posts
A friend of mine has a pair of Tv7512's with T6 .96 a/r.He would like to put them on a 400 sbc with AFR 227 heads.Would that size motor spool a T6 .96 or are they to big? If they would work at what rpm would they spool and what kind of power could they make on that size engine?What other info do you need? Thanks
Thats a pretty large set of turbos to put on a sbc. Pretty large turbine wheels.
Now 2 of them on a bbc-hell yea!!!
Just use one. Have it upgraded to an 88mm and then you'll be getting somewhere.
I have a 1.08 turbine housing for that thing if your interested.:D
Give Supernatural Turbo a call. They can help you out. If you don't get through, just leave a message and you will be called back.
Keepn my pimp hand strong
Shit I have 1. ar twin 91s on a 423 ci inch sb I leave on 7 lbs and in 2 secs have 34lbs of boost we are gonna ramp it in faster and see what happens .Those .96 ar will be great on a sbc ,everyone thinks you need a bb to run them I have been 4.71 @ 162 mph and 7.20 @ 202mph only on a handfull of passes.
1 - 8 of 8 Posts
