21 - 23 of 23 Posts
Discussion Starter #21
I went off the recommendation of Forced Inductions. They seem to think the 68 turbine with the .81 AR will be fine with my combo. I have the turbos, so I'll give them a try. I'm running full exhaust with mufflers and tailpipes as well, so not sure what the perfect turbo combo will be to make 1300 fwhp through full exhaust, but I'll figure it out.
Jose is a smart guy. I’d be interested I hearing why he felt the need to increase the compressor size. Regardless, I’m sure he wouldn’t steer you wrong.
I have similar goals but with 400ci sbf and .96 7675’s. Full 3.5” over the axle with Mufflers.
Good luck with your goals and let us know when you crush them!
Like i said i already made 1400 flywheel on a larger cubic inch 400” motor with the smaller 7268 with full exhaust . A 347 will be fine for 1300 flywheel
21 - 23 of 23 Posts
