1 - 12 of 12 Posts
i have a 408 mopar what suggestion and specs on twin bw turbos to make ,800-950 hp range in a street strip car is 3550 lbs heads are a cnc 245 cc intake runner ,4340 crank,rods probe dish pistons 9.5 comp . thanks ian
Custom Engine Shop
A single BW S480 T-6 will get you there.
single is hard to fit in a small engine bay what about twins
In an Aussie val with the engine in the stock location there is room for a single on the pasenger side if you put the bat in the boot.
later one there is but not the early ap6/vc models narrower than the rest ,
Still think that is your best bet other wise it will be fun getting a dump past the steering. It's bad enough gettingthe oil lines to clear the steering box on early val's
Discussion Starter · #7 ·
ya got that right, a real pain in the ass
Custom Engine Shop
Plasma cutter is you friend.......
Custom Engine Shop
Twin 60-66ish's could get you over 1k easy.
Discussion Starter · #10 ·
like s300sx3 come in 60/63/66 comp wheel are the s200 a bit small 56mmcomp wheel rated 200-580 hp thanks
I'm going to second Robert on this one, a pair of billet 62's would get the job done. If your using a good boost controller and you have someone tuning who knows turbos, then you could go up to a 7Xmm and have room to grow past 1000.
1 - 12 of 12 Posts
