1 - 11 of 11 Posts
what size exhaust housing's are you guys runing? say with a set of 66 or 70mm turbos on a 6 litter with 10to1 comp
I would use .80's if it's an auto with about a 5K RPM stall. This is to get the most out of them but it will be a little laggy on the street unless you brake boost. .68's with a 4K stall would be very responsive and feel quicker all around while maybe leaving some RPM on the table.
No need to have that much stall in a turbo car much less a twin turbo car.
A pair of T4's with Q trim wheels and .81 housings would be at full boost WAY before 5000 rpm.
I wouldnt have much more than a 3400-3600 behind a twin 70mm q trim .81 combo.
Twins need less stall than singles do.
will these turbo's work looking to make 1000 rwp
Cold Side
Compressor Wheel 70mm
.70 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 70.15mm
Exducer- 94mm
Exhaust Side:
Exhaust Housing T-4 Flanged Divided
Available in 2 A/R sizes - .68 or 1.0
3.0" Vband outlet
Inducer- 64.5mm
Exducer
Turbine is too small. Looks like an ebay special. You need something with a 65 or 68mm exducer on the turbine wheel.
Consider something like precisions 6076E. A pair of those are capable of 1100-1200 hp and are only 550 bucks a piece new. They have a lot of housi g options as well. Would probably be a more reliable unit that something bought off ebay.
I'm basing what I'm saying on real world experience with this specific platform. :smt102
As am I. Every twin turbo setup ive helped with hit its boost threshhold at a lower rpm than a comparable single setup... If its getting on boost sooner, why would you need a bigger stall?
1 - 11 of 11 Posts
