Hello guys I have a build that I'm working on and need a lil help
What I have is a 87 mustang coupe
It has a very mild 6.0 ls1 in it from a 2500 had truck
6.0
Carb intake
800 c&s blowthru
317 heads
Csu carb hat
Stock bottom end
Ptc converter
Turbo 400 with brake
A1000 pump 13204 reg
The car does not have a inter cooler but will have water meth injection
2 x 38mm gates
Pump gas in the road
Race gas at the track
I will have a custom cam but don't have one as of yet
The car had been set up for twin t4 turbos
And the goal is for turbos that will support 800rwhp but have room to grow without buying another set of turbos
My end goal is to have 1000rwhp
But that will be later on a built motor.
I don't mind if the turbos are a lil on the large side because I'll have the Trans brake.
This will be a street strip car I want it to performe it's best at the track mostly 1/8 mile stuff no class racing just pure fun.
What set of borg warners would you guys recommend.
6.0
Carb intake
800 c&s blowthru
317 heads
Csu carb hat
Stock bottom end
Ptc converter
2 x 38mm gates
