1 - 3 of 3 Posts
a 500 inch bbc 4.620 bore and a 3.750 stroke what can i make as far as hp with a 101mm g trim 1.5 ar housing with a blow threw on alky.does this engine need a bigger turbo to hit 1600 to 1700 hp or what will this turbo make ? it has aftermarket 320 cc runner heads with alittle work done to them and its 11.1 compression
Garrett 106mm G-trim with a 1.50A/R is the way I would go on that large a motor as a single. You could go even larger like a Garrett 115mm. The 101 will make that power but you will have to crank on it a bit. Thats a big motor to fill with a 101.
1 - 3 of 3 Posts
