1 - 11 of 11 Posts
I'm looking for a turbo recommendation. Here's some info on the combination - Street/Strip type deal
505" Pontiac (Aftermarket block IA2)
Mid - High 8's is the goal on a relatively small tire, but mid 9's would be a good starting point without the boost turned up.
4.350" bore x 4.250" stroke forged crank
6.8" Crower rod and Ross piston (Compression around 9.5 to 1)
Large Log style exhaust manifolds or headers if I can get them to fit.
Ported K.R.E. highport heads ported by Jim Robertson in Texas
Ported Victor intake (These are very good flow numbers for a Pontiac head without the pushrod moved out of the way and a small intake valve)
-- Flow sheet -- R.A.C.E. Ported
28" on a 4.21" bore - 2.20" intake/1.7" exhaust valves - No tube
Intake ports ended up @ 2.55" x 1.35" at the pushrod constriction
Sorry, I don't have all of the exhaust numbers.
__Intake_______________Exhaust__
.100__82.40_________.100__
.200__151.7_________.200__
.300__222.0_________.300__
.400__296.7_________.400__205
.500__349.6_________.500__
.600__367.8_________
.650__374.3_________.650__264
.700__374.5_________.700__
.800__377.9_________.800__
.900__382.4_________.900__
Cam will be a solid roller with .650" lift 240* - 250* duration @.050 range. Haven't decided who to go to for a grind.
'63 Pontiac Tempest Le Mans 3500 LBS - 3600 LBS
Strange 9" w/ brace, spool, 35 spline Mosers 4.10 but open to new ratio. I'm Thinking maybe a 3.50
Wilwood discs all around
Chassis Engineering Ladder bars 32" / QA-1 coil overs / 3-way Competition Engineering front shocks
8 point cage
28"x12.5" ET Streets (No tubs or back half) (Can fit 29 x 10.5 slick)
M/T ET Drag wheels all around
T400 w/ Hughes brake - No converter yet.
Blow thru carb
I'm thinking somewhere in the 101mm to 106mm range. I'd like to have some room to grow if the chassis is up to it.
Discussion Starter · #2 ·
No love for the Pontiacs crew? :(
I'm buying a turbo next week so I'm looking for a little feedback.
**BOOSTED SBF***
I will go out on a limb and say that you need a fairly large turbo if you plan to go with a single. Having that many cubic inches will restrict just about anything under 101-106mm. I don't know that these will be ideal for a street motor but you are going need a pretty big turbo to keep up with that size engine. The ideal scenario would be a twin turbo setup for a street/strip combo that size but I will let some of the other guys chime in with their opinions. This is right about where you were thinking too. We are building a 598" Ford motor and I originally wanted to go with a single but after talking to a lot of people we decided to go with twin 88's but this is not a street car.
i am with mhancock on that one... i am also doing a 598(bbc though) and was going to go single. but, cant get a single to keep up with it... I would also think a 101-106mm is going to work alot better for a 505.
At the minimum I would go with a with at least a 98mm compressor.
Discussion Starter · #7 ·
Due to space limitations I need to run a single. The car will be mainly raced at a 1/8th mile track and see a little street driving to and from the track.
Does anyone object to a PT106 with a 1.32 A/R?(One just popped up for sale) Or do you guys think a PT101 with a 1.32 or 1.50 A/R would be a better fit?
twins would be ideal but since you only have room for single I would run that pt106 and maybe get a 1.50A/R housing for it. You should'nt have a problem getting it spooled for the 1/8 mile. Is that turbo an f-trim or a G-trim?
الكتاب ا
There are several big-inch small blocks with 4.250 strokes running singles...even down to a 94mm. You will be fine with any of the larger units; just make sure you have the higher-flow turbine wheel.
Garrett 98mm will do, or a 106 as well. Just depends on how crazy you want to get. Exhaust side though, I would go G-trim turbine.
Discussion Starter · #11 ·
It ended up being a F trim so I'm passing on it.
I'm still looking for a PT101 or PT106 with a 1.32 or 1.50 A/R and G trim wheel if anyone has one for sale?
1 - 11 of 11 Posts
