1 - 5 of 5 Posts
I see some guys running a turbo mounted down low. What is being used to faciltate oiling/return to the turbo if the placement of the turbo's higher up rely on gravity for the return?
I use what you see below. Small, vented, drip tank with -10 an line going to a Turbowerx EXA pump and pumping back to the oil pan.
I run the tilton pump #8 line from both turbos to a y then from the y to the pump then pump to oil pan or dry sump tank
In a low mount turbo?
1 - 5 of 5 Posts
