Selling the Drive Train From my car, It's all Brand new and Never Run.
410 W2W Iron Long Block Pan to Valve Covers (PM for Complete Details)
• 9/16 Head Studs
• 12mm Main Studs
• O-ringed Deck
Included Parts With Long Block
• Larry Meaux AFR Heads with Solid roller valve Train
• Comp Shaft Mount Rockers
• Custom Solid Roller Turbo Cam
• Solid Roller Lifters
• ATI Superdampner
• Manton Pushrods
• Star Machine Vacuum Pump with Jones Mandrel and Aerospace Catch can
• Alternator
• Water pump
• Sheet metal Valve covers
• Solid Motormounts
• Neil Chance Converter
• AEM EMS and Harness
• Delphi Truck Coils and Harness
JW Promod Powerglide
• Trans Specs
• J.W. GM ULTRA BELL,
• J.W. CASE,
• J.W. ROLLER BEARING TAILHOUSING,
• DEEP ALU PAN,
• ROLLER ALU REAR SUPPORT,
• 1.80 GEAR SET,
• PRO TREE TRANSBRAKE,
• VASCO INPUT,
• 10 HIGH CLUTCHES AFTERMARKET ROLLER DRUM,
• 6 REV CLUTCHES,
• HP SEAL UP KIT,
• ALU SIDE SERVO COVER,
• ALU DUAL RING SERVO,
• UNIVERSAL SHIFTING ARM,
• CHROMEMOLY STATOR SUPPORT,
• AFTERMARKET PUMP
$15000 obo for Complete Setup Motor to Trans
$12000 obo Complete Long Block with Converter
• 9/16 Head Studs
• 12mm Main Studs
• O-ringed Deck
• ATI Superdampner
• Manton Pushrods
• Alternator
• Water pump
• Solid Motormounts
• Trans Specs
• J.W. CASE,
• DEEP ALU PAN,
• 1.80 GEAR SET,
• VASCO INPUT,
• 6 REV CLUTCHES,
• HP SEAL UP KIT,
• AFTERMARKET PUMP
