1 - 2 of 2 Posts
I'm new here. It's my first post actually. So I know this has been asked before, but nothing has been similar to my setup. I have a stock lq4. 9.5:1 compression. Ls6 intake. I also have a master power 76mm turbo (76mm compressor| 62mm turbine|1.0 a/r) that will be front mounted. The engine will be bolted to a t56 inside of a 2600 pound car. What I want out of the car is auto cross ability, but I want it to be streetable since it will be my weekend toy. I do not want the idle any higher than 850rpm's. What cam selection/specs do you guys suggest?
Thanks ahead of time.
1 - 2 of 2 Posts
