1 - 11 of 11 Posts
Has anyone ever done dual exaust on a single turbo setup..With say a Y right out of the turbo even length exaust each side thinking of doing something different seeing if anyone has ever tried it...Thanks in advance...
I would think not, only for the simple reason its twice as much work and creates packaging (space) problems that wouldn't exist with a single set-up.
Andy Jensen has a y pipe on his camaro out of the 106
I'll have mine split from a 5" to dual 3.5" and run back to behind the driver. Couldn't fit a 5" pipe under the car and wanted exhaust run back there for street use:)
- Brian
Outrunning the Big Blocks
I helped a guy at FFW Gainesville years ago
that had bought Baers old car.It had a 5 in
out to a Y and dual 3.5s also.They ran between the
frame and a-arms .
1 - 11 of 11 Posts
