1 - 3 of 3 Posts
what size fittings to put in the pan and best location for twin 65s on an ls engine,will be ordering the autokraft pan for this build.Thanks
I welded two -10AN fittings into my Moroso pan, about 1" back from the front pan mounting bolt on each side rail. That position lined up with the #1 main cap. This picture shows the weld-in fitting along with a -10AN straight hose end.
1 - 3 of 3 Posts
