1 - 19 of 19 Posts
i would trim the bumper. it looks better also.
Tony McKellar
I still need to trim some at the lower side I wanted to keep it some what hidden but not hurt air flow untill I decide on a molded bumper.
Aint no hiding that thing! :supz:
Custom Engine Shop
I'd try it without the tape on it first....
Looks good!
Discussion Starter · #9 ·
Well I was gonna put it inside the engine compartment but the center mount makes it easier to make the y pipe and have room for oil pump etc. I had the old bumper that had some damage so I went to cutting I just went and trimmed a little more I think I'll be ok. Robert I knew someone would say something like that I just didn't want to take it off for the pic.
Thanks guys,
Thomas
Custom Engine Shop
Thanks guys,
Thomas
If it's not dialy driven leave it right there! Flat mount the rad and enjoy.
Custom Engine Shop
This will not be driven daily if it will run cool enough I live about 5 miles from my local track and I would like to drive it in after all the bugs are worked out.
Sure it will.
Have a good rad built to be flat mounted in btween the frame rails.
Make sure you mount the fans on top and have them blow up. (reduces the under hood dirt)
You will need a high mounted spot to burp from too.
slow ass wiring guy
Sure it will.
how about more then a 5 mile trip? i want to mount my street/strip car like that but dont wasnt to run into cooling problems and have to change it back
1 - 19 of 19 Posts
