1 - 1 of 1 Posts
After having a very bad misshap on break in that took out the cam bearings in my new 533 bbf, i need a new cam, it was a comp cam. I am looking for suggestion on getting someone to build a new cam need pretty quick. Who are you guys using. Its a 533 bbf, a-460 heads, ported on exhaust side, single 106, 8.5 -1, 3300 lb mustang, 4.10 with 33/17 tires, power glide, chance 4000
bolt together converter. Looking for something in the 700 lift range good to 6800-7200 rpm range. Any one than can spec and make or order for me??? thanks walter
Oh ya it also needs to be for 55mm roller am bearings.
1 - 1 of 1 Posts
