1 - 12 of 12 Posts
Pros and cons of running one?
had a turbo company(builder) said they
dont recommend running one.
ran on for years on my old set up no problems
that I was aware of.just wanted to get others opinion.
I've always ran them since back in the mid 90s...never had an issue whatsoever. It's kinda like header manufacturers that void your warranty for using heat wrap...although, I do agree that heat and moisture can degrade the metal a bit over time, if your tune is correct, I've had wrapped mild steel turbo headers last well over 10 years without issue or need for attention. Just my opinion.
I run blankets on my turbo's to protect the fiberglass hood and the intake plumbing from the heat of the turbo exhaust housings. Don't really see a downside to running them.
Mine are out in the open. So for two reasons, I may be looking into putting some on.
1. kids walking past in the lanes make me nervous. That cast housing stays hot a long time. Even though it wouldn't be my fault, I would feel bad if a kid got burned.
2. When rain catches us, man those things rust like snapping your fingers.
I use one so I dont burn the paint off the hood. I would imagine
it does trap some heat in, bearings, etc get hotter than normal.
I have my manifolds, hotside, and turbo housing done in cerakote 1800* black. Street car. turbo is about 1 1/2" from steel hood. I have had good success, and no heat related issues under the hood in 4 years. I worry that a blanket would heat soak the turbo housing, and thus, some related parts may suffer.
Theoretically isn't that a good thing from a performance standpoint? Keeping the gasses hot there. I don't know how much difference it would make practically.
Yes. Heat and velocity are a good thing. In my case, I'm not so sure that hours long rides will be a good thing as far as retained heat in the turbo. Having said that, I'm sure lots of drag week guys are doing it.
Higher exhaust temperatures do make a very noticeable difference in spool and back pressure, in my experience. Temperature is a factor in corrected turbine gas flow, and the formula shows how much. I've not done a thorough test on this, but I've found on one my cars that is really borderline on spooling the turbo against a tight converter that preheating the exhaust manifold with the 2 step will cut the spool up time in half. And when back pressure limited it will make about 8-10 psi more boost from the heat of the 2 step just off launch, and then taper down that 8-10 psi by 3-4 seconds into the run to the max it will generally allow. That's a big difference IMO, and enough for me to consider wrapping some of this shit to see what happens with back pressure and spool up.
What is the most cost practical way to blanket these? Mine are gt45 knockoffs. I just need them not to blow off in the wind since they are out in the open.
It depends on your application. If you are on boost for long periods of time on the edge of the turbine temp limit a blanket will kill your turbo. If you are just running a 1/4 mile at a time then they work great for transient boost response. The failure of a turbine at the temp limit is actually the housing distorting and hitting the turbine wheel. The failure of a turbo in drag racing applications is usually pieces of spark plug going through them or a 10mm wrench...
1 - 12 of 12 Posts
